Official Sportster 2007 883/1200 Conversion Information
  • grafpak
    grafpak
    hi kingchops , so have you got the thundermax fitted????
  • grafpak
    grafpak
    read your link-cool!
    so with your 883-1200 conversion you bought the barrels and pistons from the states got them fitted here and added the tm-auto tune..1-did you do any head work?
    2-why did you go with the 9.5 to 1 comp not the 10-1 comp kit?
    3-i no your happy with this conversion but would you change anything if you did it again?
    thanks for the reply's...dc...
  • grafpak
    grafpak
    thanks , i already have a pc111 so i think i'll go the same way as you .
    i was looking at the 10-1 pistons mainly so i could upgrade to bigger cams later on..but maybe better reliability could be a good thing!.cheers for the advice..dc..
  • grafpak
    grafpak
    hi kingchops , aussie dollars looking pretty good !so who did you buy your 1200 kit thru?.cheers..dc..
  • grafpak
    grafpak
    cheers..dc..
  • timmey
    timmey
    Hey Kingchops
                                    thank you for the thread , good to see some one doing a bit of a change and helping other with the information .
    Just a question .... when all done , would it be better to just buy the 1200 , or have you saved a little cash and had a bit of fun in doing the mechanics
        Timmey
  • jon doe
    jon doe
    yeh my girls nghtster would beet my dyna but her front wheel starts to lift off the ground at 130 and i just pass ..but both have 77rrhp
  • dynoharley
    dynoharley
    only one way to tune a bike properly :)
