Dyna horn relocation
  • kingchops
    kingchops
    After installing the Lenale cooling fan (see here) where the horn used to be I've had a bit of a dilemma about where to relocate the horn.  After trying out several locations I finally removed the cow bell cover and stuck the internal horn in between the batter box and the electrical box on the inside of the frame.  It's totally hidden now, I'm pretty happy with it.
  • Daggs
    Daggs
    that looks cool KC, I didn't think there would be any room in there....
    Did you have to remove the battery and battery box to fit it? and is there a bolt in there somewhere you used to mount it?
    I'll be moving mine there too now... good one.
    Yes Noit that cow bell ruined my draggin jeans too
  • kingchops
    kingchops
    Daggs,
    No, I didn't need to remove the battery.  The horn fits in that gap quite comfortably, I found it pretty easy to squeeze it in the gap from the left side of the bike.
    You can bolt it to the back of the battery box, but I suspect the head of the bolt on the inside would hit the battery.  So all I did was attach a big size zip tie to the back of the horn using a metal tab, then I removed the seat and fed the zip tie through and I just tied it to the top of the battery box, ie there's a gap in the back of the batter box near the top which you can slip a zip tie through.  Then I just pulled it reasonably tight.  That was enough to secure the horn from moving forward but still allows it to move slightly.
  • Daggs
    Daggs
    sounds good, cheers!
  • kingchops
    kingchops
    Good spot there Wozza. We should start a movement: "get rid or the cow bell".
  • Pom58
    Pom58
    I kinda like the cowbell--- MMMMM Shiney!!
  • Daggs
    Daggs
    nah its a piece of shit... i like the V2 donk.... fuck off the cowbell and see more of this glorious motor and at the same time stop ruining yr jeans just my drunk (and hard lived) 2 cents worth
    btw... KC, there is no way my horn will fit in where you have yrs, mine has a heap of crap already taking up room there. stuff for the active exhaust, i already have mine disconnected and have tghe plug "eliminated" but yrs must have even more components removed??
  • Daggs
    Daggs
    nah its not from the pc3, i fitted that myself, it looks like its the active exhaust components but doesn't matter.... main thing is that its moved from its std position.
  • kingchops
    kingchops
    Rodders,
    C'mon admit it, you love the cow bell.
  • MapleLeafs
    MapleLeafs
    Boys playing with their horns. After seeing today what has happened to Noit's trousers from his horn (hahahahaha) I understand why you guys want to do this.
  • vudoo
    vudoo
    Would relocating the horn make my softail unroadworthy? I am in the process of relocating my horn and want to cut the original tab for a clean look. Jus want to know in case I ever have to get a RWC
  • terroristone
    terroristone
     it dosnt matter where it is on the bike, as long at it works.
    T1
  • vudoo
    vudoo
    Good to know, time to do some modding.
