Heartland EZ 200 kit
  • dodge
    dodge
    G'day all,
    Anyone had experience with the Heartland EZ 200 kit?
    If so which fender did you go with and is anyone runnin the shortest version (wild heart) because I'm trying to work out how you could incoporate a plate and tail light into it.
    I know there are the swing arm or footpeg versions you can hang off the side but would rather have it on the fender - less attention paid to you that way I'd expect!
    If you've bought a kit - how'd you go for price?? About $4500 painted and fitted at one joint in WA. Costly.
    Cheers.
    Dodge
  • kilpac
    kilpac
    Hi Dodge,
    I will watch this thread with interest.  I am looking at a 200 kit for my Dyna, price is about the same as I was quoted here in the ACT.
    Cheers,
    Chris
  • Frank7214
    Frank7214
    Got the same quote from ACT for my Rocker. I would go with the longer version guard with frenched in tailight.
  • Daggs
    Daggs
    kilpac, what year Dyna do you have?
    for the 2006 and up you don't need any kit, well not a new swingarm or guard at least, just a 5.5" or 6" rim and some shoe-horning
  • kilpac
    kilpac
    Hi There,
    I have a 2000 Model FXDX, so if you know of an easy way to get a 200 in there that will not cost me 4k I am happy to know.
    Cheers,
    kilpac.
  • Daggs
    Daggs
    no sorry I don't know about the 2000 model, I did my 2008 no probs
  • chriso
    chriso
    So does anyone know is the longer 200 heartland fender available with plate integrated into it?
    Also how is the ride with these kits? Guard seems close to wheel which looks the part but some feedback on quality of ride would be good.
    Anyone got one?
