Online: obisteve, speedzter
Rider Backrest for Road King
  • twincam88b
    twincam88b
    Anyone had any experience with them, and what sort did you use. I think there is a fair range in the accessories book. Personally I don't like the look of a bike with 2 backrests on it, but I'm considering an interstate trip and I'm sure it would help with my crook back.
    First thing I'm going to try is a sheeps wool seat cover.  I bought one for the wife's Virago last year and it fits well and is pretty comfy on the tiny bike. However I didn't ever do a long trip on it, why would I.
    TC
  • nobody
    nobody
    Personally I would sort out the seat before I worried about a rider backrest,as the standard seats are not the best for any sort of support over any sort of distance.
    nobody
  • twincam88b
    twincam88b
    Thanks nobody, I haven't heard of the Danny Grey seat, and Mustang probably make one as well.
    TC
  • twincam88b
    twincam88b
    Just found the Danny Grey website...............
  • nobody
    nobody
    twincam88b
    I have the Danny Grey Big solo seat,which is a buttcrack design.In my opinion,for myself,it is extremely comfortable over longer distances,much more so than the Harley Pillow look touring seat,that I use when the wife is on the back.Even though the Danny Grey feels very firm when you feel it,I find that it offers much better support,hence more comfort.Mind you,that is just me,as I have had other people sit on it and say "I don't know how you could ride on that thing" guess it just suits my shape.Mind you, the people that say that haven't actually ridden on it.Their quality is absolutely 1st class,they are used by most of the best known custom bike manufacturers in the U.S. so their quality is show quality,I would have no problem buying another one,if I could only persuade my wife to give up her pillow look seat .
    nobody
  • nobody
    nobody
    I know a lot of people use and really like the Mustang seats,I just never saw any that took my fancy,and besides,they are too common,I like a bit of originality as well.
    nobody
  • twincam88b
    twincam88b
    Thanks for that Nobody, I will have to look into this problem further. Something is just not quite right.
    Funny enough on the Softail I mostly rode with a LePera bare bones, unless I needed to go 2up, and I had less hassles with the back bone. Work that out.
  • nobody
    nobody
    twincam88b
    Dont know why I didn't mention it yesterday,guess it must be fatigue from working shift work or something
    The one thing I found with the roadking is that with the standard handlebars you tend to lean slightly forward,unless you are very tall or have very long arms,this tends to put a lot of pressure on your lower back and really can make your back ache,particularly if you do a lot of Km .A lot of people ,myself included have replaced the handlebars with bars that allow you to sit more in an upright natural position,taking the pressure off your lower back.I think rkc is also thinking of doing something similar and he is fairly tall.This may be something that you might like to think about,as I know it made a big difference to me,I now sit back happily and wath the kms go by with no back pain.
    nobody
  • twincam88b
    twincam88b
    Thanks for that Nobody, yeah I rekon it's the bars, and I notice the chubbies are the go. The Harley cataloge has bars that drop back about 2  1/2 inches, but they will probably be dearer. I will try and see what other Road Kings have, and maybe chance to sit on one and see what it feels like. Next time I go to Peter Stevens I will see if they have any second hand bikes with the different bars. Best bet would be to atten a rally where there are a heap of bikes, eg HOG event and check out the different styles that people have chosen. The handle bars have been discussed in length in another forum......TC
  • nobody
    nobody
    or you could take a short ride to Sydney,and I would let you sit on my bike to check out the bars
    nobody
  • twincam88b
    twincam88b
    Thanks nobody, trouble is I want to head to the West.....
  • Hobo
    Hobo
    I've got an Electra Glide with a Sundowner Seat, back rest for rider and backrest for pillion.  I've also got  a very luxuriously deep pile lambswool cover and the combination allows me to ride very long k's.  Been interstate and country from Melbourne many times and not the slightest ache, and I have a broken spine held together with titanium rods and screws.  Yet if I jump on my wife's bike and test ride just around the block (no rider backrest) my back is extremely  sore.  I can highly recommend my combination, used over many years on my 2001.   HOBO.
  • RKB
    RKB
    We have the HD version and HD touring seat, both the seat and back rest allow you to knock up some decent daily runs in comfort.
  • groover
    groover
    I have the Sundowner seat on my RK as well.
    Trouble is that it's a new 08 model that has the "fly by wire" throttle and apparently the bars are different to suit. Don't know normal bars can be addapted to suit.
    Wouldn't mind fitting a set of 10 - 12 inch Heritage type bars to straighten my back up.
  • rkc07
    rkc07
    groover
    have a look at the american site ... they seem to be doing the bar changes on the FBW systems no worries ..just some things to think about thats all when it comes to it
  • gonzo
    gonzo
    I replaced the stock seat with a sundowner on my 07RKC. I had one on the previous Dyna and it was great. I do a lot of Ks with the wife on the back - need a comfy 2-up seat. I also replaced the stock bars with the reduced reach ones (2-1/2" closer). They really make a difference for me, because I'm short, and I didn't like the "leaning forward" stance either. The only pain with the bars is that they use internal wiring and you have to re-pin the plugs to feed the wires thru the bars. Very difficult.
    Gonzo
  • twincam88b
    twincam88b
    Thanks for all the info fellas, I've still haven't changed anything yet, not in any hurry. I have had the leg/back treated by a remedial massage mob, and that has helped a lot. Will keep on checking to see if there is any other good tips. I do agree I think the bars are the problem, (slight reach forward) may need to go the short reach bars.
