Online: Soapbox2627
Puncture repair-Softail tubeless rear
  • Lastrain
    Lastrain
    If it were me ... I would risk it and keep the tyre on and keep a real close eye on it, I've had a good run with both the plugs and goop (not in a road bike tyre though), I've had plugs last the full life of tyres on dirt bikes, quads, cars, 4x4's and trucks surely using both together must work out alright?
    I would expect the "not for motorcycles" statement is just the manufacture covering their arse.
  • Yob
    Yob
    Had a flat on a snowy mountain ride on a jappa sports bike, repaired with plug & goop, did 1400kms @ wrong side of speed limit
    did not have an issue until i pulled the tyre from the rim & the end of the bolt had damaged the sidewall.
    if the rear deflates you still have control, i was doing 150+ when it went, no warning just a big weave going into the corner.
    if its a front tyre then your face will meet the road real quick.
  • philthy
    philthy
    Another rocker owner said to me that the pressure repair pack type stuff has to be the right stuff. The rocka 5 spoke mags are expensive top shit metal and some pressure pack "fix a puncture" stuff can have a chemical reaction to the alloy,pitting and so on. Basically fucks your mega $ rim. I'd like to know anyones thoughts about that for my own sake.   Plugs and a pump are the go, but what about the liquid crap on certain type wheels?
  • philthy
    philthy
    Your dead right there RT,couldn't have said it better myself. I did use the plug on my '84 (solid rear rim)in the states and got me out of a spot I was in so quick.
