Online: Retroman
Wild 1 518 handlebars
  • nobody
    nobody
    Hi rkc
    You will require 2" over throttle and idle cables and you can use a stock length clutch cable.You would be better off useing longer brake lines as well,but you can use the standard brake lines,just need to bend a bit at the top,I didn't want to bend mine so I got some braided lines .
    nobody
  • nobody
    nobody
    Gee so your wife is happy with just 3"
    nobody
    And yes 2" longer will do fine.I got mine from MandMcycles in the U.S. heaps cheaper than getting them here
  • nobody
    nobody
    are you going to get braided or standard cables?
    nobody
  • nobody
    nobody
    Am off to work now,but when I get home I will see if I can find the part numbers for you.You will get braided lines from MandM cheaper than you will get standard here.
    nobody
