Online: John.R
standard exhaust removal
  • wax035
    wax035
    Can anyone tell me how do you remove the exhaust shutter from a standard exhaust???? removing my exhaust from a 2009 street bob to fit some vance and hines big shots. Advice would be greatly appreciated
  • Wingy
    Wingy
    http://www.hdparts.com.au/Default.aspx?tabid=71&forumid=15&postid=127464&view=topic
    Have a look here.....I did nine a while ago now with no problems...looks alot better wihout all that shit on there....but its true duals now and fairly loud but I think it sounds alot better now.....fairly easy job to do 2 or 3 hours tops.. but I would get new gaskets for the header pipes in the head next time.
  • wax035
    wax035
    cool thanks but what about the cable that runs up between you battery and ecu?? not sure on how this disconnects?
  • Wingy
    Wingy
    Sorry for the delay busy as at the moment.......cant help you ...every thing was disconnected on my bike from new..........self tapper in mine.................someone else on here should be able to help you.
