New inner cam bearings question
  • berms
    berms
    G'day fellas, I have most of the parts on order to change cams in my 2010 bagger.  When replacing the inner cam bearings, does it have to be the Torrington bearings??  All I could buy at the time was JIMS Inner cam bearings.....
    Are the JIMS OK?   or should I go and find some Torringtons?
    Thanks.
  • jordan
    jordan
    they way to tell is if there is no space between the rollers, they are what you want... if there is a cage dont use em
  • berms
    berms
    Posted By jordan on 22 Nov 2009 11:41 AM
    Thanks, there are no spaces between the rollers so they look to be good.
  • berms
    berms
    Posted By Ozroder on 21 Nov 2009 5:58 PM
    The Jims bearings will be torringtons........................Ozroder
    Thanks for the confirmation Ozroder.
