Leaking rear header pipe
  • Magilla
    Magilla
    Had my stock exhaust put back on for the run down south (save any defect hassles) and noticed both header pipe bolts had come loose. The rear was leaking.
    So I removed the pipes,check and put back on. Now the rear header pipe is leaking worse.
    Any tips when installing pipes? What to look out for, sequence when installing, i.e. install- tighten rear first, install while cold/warm/hot etc. Any help would be appreciated.
    Mag
