MAP suggestions
  • rockyrob
    rockyrob
    Hi  I have tinkered with my MAP  and  would appreciate someone having a quick look at it just to make sure theres nothing untoward before i load it.  I have also found a map that Scotty made in an old post which  may be a close fit to the bike,
    09 Fatbob stock with SE Heavy Beather and Vh 2into 1. SEST  Current set up seems to use a lot of fuel and just doesnt feel right( like its slightly off time )It seems to stumble on take off and vibrate thru the gears under load. I have two maps which i plan to try( one is yours Scotty) .If anyone has a spare minute and the software could you please offer any suggestions or comment you feel might assist me,  In particular  i notice the closed loop bias is a lot different  798 in my existing map compared to 680 in Scottys ,and the spark advance tables are quite different from 750 -3000. I am guessing but thats where i feel i may have an issue .My hope is to combine the two  and get a MAP close enuff to then run the smart tune for final adjustment
    Thanks in advance, Hopefully i will  get to the stage when i can actually start answering some questions and not always be asking
    Maps can be downloaded  here sorry i dnt know how to link it direct it needs pasting into the address bar
    http://www.box.net/signup/collablink/d_34293554/723d66536883a
  • rockyrob
    rockyrob
    Thanks for going to so much trouble Scotty it really is apprectiad by me and i am sure heaps of others. I intend running the smart tune this weekend to see how it goes. It certainly is a steep learning curve using a laptop instead of a changing jets in amals and using a strobe light but i am learning.  :)  I even knew what CLB was without having to think too hard, lol
