Online: Merv
Perished HD aircleaner WTF!
  • Magilla
    Magilla
    Hi all
    I'm giving the bike the 'once over' and clean before the run down the guts to the pub challenge.
    Pulled the air cleaner off and it seems to have perished (again)
    I say again because it happened to the last one as well. (about 1000km)  I put the last one down to - maybe old shelf stock or the stealer damaged it when thy put it on. I put this one on.
    The rubber is falling to bits, perished. It is the bottom of the air cleaner so I'm wondering if fuel is leaking and stuffing it. (you'd think an air cleaner would be fuel tolerant!!)
    Any ideas, suggestions, is there a better alternative? This is a genuine HD part.
    This filter is about 3000km old
  • Magilla
    Magilla
    Had a look at the butterfly valve and it looks like the rubber has been getting sucked into the engine
    Before
    After
  • Magilla
    Magilla
    K&N it is then. Don't know who supplies them in Darwin. It's just as quick and cheaper to buy down south.
    Any suggestions as to who to buy from?
    From what I can see they are around $100. ????
  • monarofan
    monarofan
    had a K&N HD-0800 fitted to my 09 fatty buy the dealer from new, no troubles so far
  • aussiesport
    aussiesport
    i know this sounds wierd but is it carby or injected and has it ever backfired thru the throttle ?? if iy has it could be blowing the path of least resistance or weakest point in the rubber ? also oil sitting in bottom of cleaner ! had a sporty once that spat the entire cleaner assembly and carby off the manifold once due to start up backfire thru carb ..
  • CHARLIE
    CHARLIE
    Go and see Matt at Motorcycle Territory in Hickman street or ring him on 89470042.I have K&N in my Ultra No problems.Charlie
  • aussiesport
    aussiesport
    good luck bud hope it dont do it again :)
  • philthy
    philthy
    My 08 Rocker stock filter perished the same way,fucknose! has been replaced with an aftermarket jobbie. Prob solved.
