Online: Stuart, Merv
Alarms
  • harleynt
    harleynt
    I had one of these on my previous bike
    A few minor problems were where to put the antenna to get best reception and occasionaly had to refit the battery
    otherwise a very good unit, you will prob need to disable the perimeter alarm as it will go off all the time. Mine became u/s and i didnt replace the module
    A much better solution than HD standard alarms fitted
