Online: speedzter
Layback Number Plates
  • SAV351
    SAV351
    I appologise up front I'm new to this whole bike thing so I don't know where to look or how much to spend.
    Where do I get these Layback number plate mounts to suit a 08 Fatboy (and I don't want to drill the guard) I've seen them on a few bikes and they look the part, I can't cop the billboard look on the back of my bike.
    p.s Are these illegal in NSW
    thank you in advance
    SAV
  • Cranky
    Cranky
    I use what your saying, zodiac rear slant mount comes with 2 peices of rubber etc for diff angles. Then a Genuine Harley numberplate surround looks the goods, still end up costing ya over a Hundred for it all.. But thats HD Hundreds Dollars lol
    I didnt have to trim my plate and IM in vic, just had to realign 2 holes i think it was.
  • Frank7214
    Frank7214
    Hope this helps
    (1)   The vehicle number-plate issued by the Authority for a vehicle must be permanently affixed to the vehicle so that (assuming the vehicle to be on level ground):
    (a)   the number-plate is at all times:
    (i)    in an upright position that is substantially parallel to the vehicle’s axles, and
    (ii)   not more than 1.3 metres above ground level, and
    (b)   the number-plate is not obscured, defaced or otherwise not legible, and
    (c)   the numbers on the number-plate are clearly visible from a distance of 20 metres at any point within an arc of 45 degrees from the surface of the number-plate above or to either side of the vehicle
    is c is clear, clean, untinted and flat over its entire surface, and
    (ii)   has no reflective film
  • SAV351
    SAV351
    Thanks fellas, just ordered a kit from the ebay link that kingchops posted and I got the one with a chrome plate frame as WozzA suggested. Thanks for the legalities advice Frank7214 I suppose it will match the other illegal things on the bike that are suppose to kill people like my exhaust, smoked blinkers & hiflo airfilter
    thanks again
    Sav
  • SAV351
    SAV351
    Just got the Lay Back plate kit went on easy and looks oh so much better again thanks guys
    Sav
