Online: tussuck
James gaskets any good?
  • kingchops
    kingchops
    Got my V-Twin big bore kit today and it comes with James brand base and head gaskets.  Just wanted to ask whether these are any good or should I opt for HD gaskets?
  • snagger
    snagger
    James gaskets the go mate,they been around for donkeys.
    same goes for all the the other james stuff.
  • BACAMICK
    BACAMICK
    what did u end up with ?
    nothink wrong with james
  • kingchops
    kingchops
    Seems to be a bit of a consensus that James gaskets are the way to go that's great.
    Mick - ended up getting the V-Twin Manufacturing 1200 kit with dish top Wiseco 9.5:1 pistons, Kit comes with James head gaskets and Hastings rings.
    On inspection of the jugs the castings and machining look pretty good.  Overall I'm pretty happy with the look of this kit.  $570 AU delivered.  Decided to go for a mixture of black jugs with silver heads hope that works out ok?
    I'm getting it fitted on Monday so will let everyone know how it goes.
  • BACAMICK
    BACAMICK
    looks good mate  them barrels are a lot chuncky than the stock hds,
    whod u get that kit of ?
    who is installing it 4 ya ?
    ive heard some shops arnt keen on fitting usa imported gear
  • BACAMICK
    BACAMICK
    i figgerd ur normal wasnt doing it , theres a couple other around that will but if u have it sust its all good
  • Big Joe
    Big Joe
    KC them gaskets are the go mate. Never had any probs with them.
  • jim76
    jim76
    is it up n running yet kingchops? havent heard any thing yet unless i missed it.
  • snagger
    snagger
    Had a look at that ebay site K.C.you couldnt go wrong their strictly sporster from what i seen.
    made me shudder a bit.
