Online: Soapbox2627, FatMat
o2 Sensor Sockets on V&H Pipes
  • 2005 FLSTFI
    2005 FLSTFI
    Does anybody have a photo on their PC of a set of V&H Pipes with the placement of the o2 sensor sockets. I,m just about to weld these on to my existing pipes and would like to know where they are welded on. Also I had a look at some stock pipes last week and the sockets were welded about 45° from the pipe. The actual sensor tip itself looks like it would only sit inside the pipe, would this give a proper reading.
  • 2005 FLSTFI
    2005 FLSTFI
    Dave
    Cheers for that info, if you had no issues I'll do the same. As you won't be able to see the sockets I'll just MIG weld them in
