Online: beaglebasher, Stuart
MicroTach results
  • outbak
    outbak
    i bought one back when our dollar was real strong a year or so ago.... i guess i should get around to fitting it one day.
  • outbak
    outbak
    Fitted it on the weekend. Was easy once i figured out how to turn that bloody alarm off...........
  • LOW06
    LOW06
    So lads how much is this micro tach? and where do i get one? Aftr fitting stage 1 kit and mikuni im not sure where my revs are or if im anywhere near the limiter. Steve
  • outbak
    outbak
    Low06 - just google "microtach"
    Bucket - Those traffic light things must really suck.... :)
  • pistol pete
    pistol pete
    yep i know when to change up a gear when the fuel cuts out
  • pistol pete
    pistol pete
    when the valves start bouncing
  • Taffymarsden
    Taffymarsden
     I'm picturing getting gingerly off the bike with a piston up my bum after the limiter failed...(ok, I'd have to be sitting on the tank for that to happen but it's a good image...)
     hi, if your going to hit high rev's it's better to do it maybe in 2nd or better 3rd at least you will  won't be over reving the donk  for no speed value ,  3rd & 4th is cool ,  cheers
