Footpegs
  • Sparra
    Sparra
    Hey folks...I have a 95 Softtail that had the standard pegs on the forward controls...i didn't like them and found them to narrow so put some after market running boards on it..they were great comfort wise but always scrape and that gives me the shits...I then put some standard type pegs on but much wider than the originals but my feet keep sliping off as soon as i start to relax...Anyone have any thoughts on a good set of pegs???I was thinking the stirrup type but everytime I try something that doesn't suit it's costing me $... so thats why i'm looking for ideas...
    Cheers...Sparra
  • majorboot
    majorboot
    steamer..try a set of Kuryarkyn pegs..they are flat and wide but you'd probably want to match them with the driver pegs as well or the bike will look odd.
    I have a set for front and back, got 'tm off ebay in the states and shipped 'em over,...cheaper than buying them from here @ full tote odds..will try and find some pix for ya if you like.
