Throttle Cable adjustment
  • abrolhos
    abrolhos
     Hi Guys,
    I have just changed my grips on my Fatbob from Standard (Cheap) Harley ones to expensive Harley ones.
    Change over went OK however I just want to be sure that the throttle cable is adjusted correctly.
    Can anyone advise on the standard /recommended process.
    Don't want to go down the road at full throttle. Could be a bit fuggin ugly.
