Online: HD17
Cams Again
  • Tbolt
    Tbolt
    Just want peoples opinion on some cams
    Either SE 203 or 204 cams which is better for
    a stock 1450 with hi flow air filter and V&H exhaust
    and Crane Ignition module ?
    Lookin at barrels and pistons to 95" at a later date...........
    So which is the better option?  203 or 204
    Any help would be great...
    Thanks
    TB
  • cosmic
    cosmic
    204 are far better than 203 but be carfull if you are going to do a big bore kit cause both of those cams will increase static compression you may want to wait till you can do the hole job in one go
