Online: HD17, softfat
Does 2008 Fatboy tank fit on a 2008 Softail custom?
  • Hidiho
    Hidiho
    Hi All,
    Been doing some hunting for a replacement tank and came across a FLST 2008 Tank,  I'm under the impression that the tank should fit straight on my 2008 Softail Custom but the seller came back and said it wouldn't fit.
    Can anyone confirm whether the tank will fit or not as I would have thought the FLST tank would fit the 2008 Softail custom without any problems.
    Hidiho
  • Hidiho
    Hidiho
    Well,
    I came across another Tank and this one states that it will fit FXST and FLST so looks like I am on the right track now..
    Thanks for the reply Robo, I had a feeling that it would fit but thought I would ask the seller anyway...
