stator connection plug oil leak
  • damo
    damo
    I have oil leaking around the stator connection plug and have read that using
    a small oring fixes it, problem is my wires are soldered into the plug.
    Would it be ok to cut the wires halfway between the plug and regulator
    and fit oring to leak then rejoin them ? It's an 89 evo.
    Any help would be appreciated.
  • houli
    houli
    Would it be ok to cut the wires halfway between the plug and regulator.
    Yes, as long as you rejoin them well, i`d go solder and heatshrink.
  • damo
    damo
    Used good ol silastic around the plug and seems to have worked for now anyway.
    Will look at replacing  later on.
