SEST CD and Cable
  • rockyrob
    rockyrob
    Dealer quoting up to two hours to retune my SEST after i fit new cleaner and pipes on my 09 Fatbob depending if it is just a base map or he tickles with the data after a run , personally i would have thought there must be a map for that configuration already as its got to be pretty common.,currently SE breather and SE slip ons going to SE Heavy breather and V & H 2/1
    I can get Cd 32111-09 and cable 32184-08 for $70 au from US as i have some other stuff ordered . Question is  are they the right parts for the SEST and is it easy enough to tune remap and tune,  I have read heaps on the SEST and theres lots of info on the forum .I am a little computer savy but no experience in tuning at all
    Rob
  • rockyrob
    rockyrob
    Thanks Scotty,  and that will work with the SEST?  (  i think its the latest  i have not really looked at the thing but it was purchsed only a few onths back)  When you look at the CD does it list the avail maps and what they suit  i.e  map 1234 = SE heavy brether and certain sort of pipes,  or how does a person know which map to start with
  • wildchild
    wildchild
    Scotty,
    How good is the smart tune feature in 32111-10?
    Will new software be OK with an 08 VCI?
  • rockyrob
    rockyrob
    Thanks for the info Scotty  , i checked and its got the red button. I will buy the kit and play with it with the SE slip ons while i learn about it and wait to decide on the V & H . The note of the slip ons seems more meaty that the  V & H  so its just the look  that is swinging me that way  and with  SE heavy breather and SE slip ons  there should be a HD map i would guess
