Know of a bike stand/lift that can then wheel your bike around??
  • SuperGlide
    SuperGlide
    Running out of space, wondered if there is a    bike stand / lift that will lift bike, then have good enough 4 wheels that it can
    move the bike around the garage. Need something that can move on normal (bit gritty dirty) cement floor not polished workshop floor etc.
    Seen something like this at a decent price???
    Many thanks.
  • Ink
    Ink
    Yeah superglide, have the same lift purchased from repco.
    Was on special at the time for $150.
    Very happy with it so far...
  • bozhog
    bozhog
    hi mate...i purchased my bike lifter from repco ...it was $149.00 and works great...comes with tie down straps so you could  carefully move your bike around if needed..
  • Soapbox2627
    Soapbox2627
    my $149 one from repco has never worked, I have tried every thing to get the jack to work so I may have to buy a new jack
    I had it for 12 months before I opened the box so there is no warranty
  • SuperGlide
    SuperGlide
    Cheers lads.
    I'm not sure if you can easily/safely wheel the bike around with any of these though?
  • SuperGlide
    SuperGlide
    OK sweet, I will give the SA # a call tomorrow. THANKS.
    You don't have a brand/product name so I can have a look at it on the internet box?
    Hold that, Found it.
    Will order one tomorrow (as old skool site with no web ordering/credit card etc) on your & Bacamick's recommendation.
    Anyone interested website is... http://users.chariot.net.au/~brendansmg/index1.html?target=d1.html
    Or if that does'nt work go to... http://users.chariot.net.au/~brendansmg/
  • gonzo
    gonzo
    Hi Guys.
    I bought an IB bike lift. It works OK, but the castors are too small to push the bike around when it's off the ground. You need a highly polished floor for that.
    Gonzo
  • SuperGlide
    SuperGlide
    Ordered just now, he did it for $150.00 and delivery to Sydney for $33.00, said he'd Startrack it off tomorrow.
    Could'nt be easier.
    Thanks for your help guys.
    Will report back with thoughts in next coupla' weeks.
  • Ozbiker69
    Ozbiker69
    Shit I am glad that i read this one for sure... Looks like i will be on the Dog and Bone in the morning to order one myself
  • SuperGlide
    SuperGlide
    OK it arrived, very fast etc.
    I have assembled no probs, peice of cake, instructions are "ok", make sure you install safety bar too as this and couple of small things are not mentioned in the Chinese translation at all.
    SO.... ////// HELP ///// HELP.... HELP....
    I can only hoist the bike if its sitting on the (folded up/in) kickstand!?
    With stand down it can not get a good placement and hits the spring etc. With stand up you can take front cradle up to front frame welds and it hold OK but back left corner is pivoting on the raised stand leg, is this OK??
    I can barely roll it around as the weight on the castor wheels makes it quite tough, if I stapped the bike down on the stand properly though I would have more of a chance. Where are you guys putting your tie-down over the bike?? I don't reallly want to squash the seat for long periods etc and don't want to touch the paint.
  • gonzo
    gonzo
    Hey SG,
    With my IB lift and RoadKing I have to put the lifter on an angle to clear the sidestand, so the bars of the lifter are not square across the frame of the bike. It's not a problem. I know both your lifter and bike are different - but it might help.
    Gonzo
  • SuperGlide
    SuperGlide
    Cheers for the tip G. Yeh will have a look.
