Anybody put O2 sensors in pre 2006 bikes
  • 2005 FLSTFI
    2005 FLSTFI
    Finally got my stuff from the US for installing O2 sensors today (& thanks to DodgyDave for the weld-in bungs). Looking at some stuff & I,m confused as to what stuff goes where.
    1. Does anybody who has done this know if there is special cable needed for the connection of the sockets (P/N 72007-05).
    2. Where does Terminal Socket (P/N 72076-00) connect to as mentioned previously I only need 2 of these.
    3. What are the little yellow wire seals for (P/N 72011-05).
    4. Is there special tools needed for this installation.
    Cheers for any responses in advance
  • 2005 FLSTFI
    2005 FLSTFI
    Thanks Scotty
    Explained to a tea.
    Yes I have a service manual, but it's for 05 models.
    Is there a special cable that is needed or can I just use automotive cable
  • 2005 FLSTFI
    2005 FLSTFI
    Ok these next questions are more of a safe than sorry question.
    1 wire from each sensor connects to terminal pins (P/N 72076-00) at the ECM & the other wire from each sensor connects to ground.
    Are there specified slots in the ECM plug for these terminal pins (P/N 72076-00).
  • grahamjb
    grahamjb
    On my 2008 FHLX, the rear O2 sensor connects to pin 46 and the front O2 sensor connects to pin 66 on the ECM - I don't have a circuit of your model.
  • Steve Cole
    Steve Cole
    If you have Mastertune look in the Tuning Guide Appendix A. Everything you need is there.
  • 2005 FLSTFI
    2005 FLSTFI
    Graham JB - Thanks for your input.
    Scotty - Thanks for all this, looks like everything has been explained, will tackle this job in the coming weeks. Will let you know how I go
    Steve - Looked at Mastertune Tuning Guide Appendix A, doesn't tell me anything unless I,m looking at the wrong revision.
  • grahamjb
    grahamjb
    2005 FLSTFI
    The wiring info is on page 82 of Mastertune handbook version 1.2 - can send you a copy if you PM me your email or fax.
    Can also help you with terminating the cables if necessary.
  • 2005 FLSTFI
    2005 FLSTFI
    Thanks Guys
    I was looking at a diffrent Appendix A. I don't have my SERT upgrade to TTS as yet, hopefully today or tomorrow but I take it all the above information is in the package when I recieve it.
    Also I was thinking of running an MT6 file for the time being until I put the sensors in. How does a 127HD019 map sound for what I have.
