HELP! Re: Kuryakan Blackwidow grips
  • vmax
    vmax
    $150.00n Adelaide roadtrain and thats with "the works"
  • vmax
    vmax
    Jilli...you probally need to a shop like Blackwoods or Universal Fastners if you have these up your way.A shop that sells to engineering type shops...check oput your Yellow Pages
  • GeeBee
    GeeBee
    Try engineering shops - I once got a bolt for a sissy bar on my old 96 wideglide ( lost whilst riding across Victoria ) at a irrigation engineering supply shop in North East Vic - fitted perfectly !
  • Soapbox2627
    Soapbox2627
    Jilli
    I think "Show and Go" are the Kuryakan dealers in Adelaide, I know you don't live in S.A. but if they can help its worth a call.
  • sly-1
    sly-1
    I have an old set of kuryakin grips flamed how many end bolts do you need
  • toxic
    toxic
    hey Jilli hope ya find one, wot I do when I lose one, is remove one thats the same, ( from where ever ) & take that to an engineering mob or the like, have them track it down & buy a couple, surely something like a bloody screw should be easy enough to source .... best of luck ....
  • sime69
    sime69
    Jilli, I might have some too...I'm assuming they are the same as the little Allen head bolts that Kuryakyn use for their ISO grips. I bought a Throttle Boss to go on mine, which came with longer bolts so might have the orig ones somewhere.
     I found the same problem with them coming loose on Kury Stiletto foot peg caps  - use a drop of blue Loctite next time rather than doing em up tight, its easy to strip the Allen thread!
  • majorboot
    majorboot
     buggah me...never thought I'd see the day when a woman couldn't get a screw....(even a LITTLE one)
    Let me know how you go Jilli..Mic is heading to the states in a couple of weeks, I'll get her to chase one up for ya.
