Slot cutting tool advice
  • kingchops
    kingchops
    I'm getting ready to do a few mods to the Bob.  I want to internally wire the bars, relocate the ignition to the centre console and relocate the indicators from the bars to the forks.
    I've got most things I'll need but I'm after some advice on a good bit I can use after I've drilled some holes in the centre bottom of the bars to cut a slot.
    What I want to do is drill a series of holes about 25mm wide and then join all the holes to make a slot about 25mm x 6mm.
    I figure I'll get some sort of mill style drill bit to cut the slot but was wondering if anyone could recommend a good brand of bit and also a good place to get if from?
  • AJ56
    AJ56
    KC I have a dremel with a heap of cutting discs that would probably do the job for you, As long as you have a steady hand it should be ok, what are you going to do about the bear metal after you cut the holes? A prime candidate for rust unless you coat the faces with some zinc oxide to prevent it setting in.
  • WhatTaxi
    WhatTaxi
    slot cutting tool ? ................ i just call it me dick
  • Purnong
    Purnong
    After you do the drilling KC, just go and get a decent hand file, be done in no time
  • 1elcys
    1elcys
    Good onya KC it'll make a world of difference to your Bob.
    Tungsten carbide burr is the bit you want for your Dremel, it'll just about grind through anything.
    You can get a cheap Black and Decker Dremel type tool it has a 2 year warranty and is cheaper and just buy the Dremel tungsten carbide burr, it will be about $40 just for the burr.
  • gonzo
    gonzo
    A man who has a Dremel can do anything! Go for it KC! If you don't have one, here's the excuse you needed.
    Gonzo
  • kingchops
    kingchops
    Thanks all for the advice.
    Yep, was thinking getting a dremel, sounds good. I've ordered me a set of burrs and I'll start shopping around for one.
  • AJ56
    AJ56
    If you need one in a hurry you can borrow mine. I don't use it that much. Up to you KC
