Online: Stuart, BigKangaroo
Rear wheel bearings
  • nitrohd1
    nitrohd1
    Normal shipping time via airmail to Brisbane is around 5 working days! How come you're quoted 2 weeks?
  • Phillthy
    Phillthy
    I tried that, no good.
    They are some brumby imperial size that Harley must get made and they couldn't match it.
    The guy was looking through a heap of different suppliers books as well.
    I ended up getting mine from the states, had the time to do so and shipped with other bits and pieces.
    Good luck with it and if you do find some here in Oz, let us know where.
  • Rooster
    Rooster
    Hilly, I have an SKF next door at work. They usually know there shit for the mining sector.
    If you send me the details, sizes of what you want I can go next door, grab it and stick it on Followmont to Brownsville.
    If they have it in stock it could be there overnight!
    Drop us a line if you want.
  • Daggs
    Daggs
    Those sizes, mainly ID of bearing will be dependent on year of bike too of course.
    2008 and up Dynas (for example) are 25mm I believe..
    My 08 is anyway
  • trainman
    trainman
      My bike is an 06 XL with a 1" rear axle. Would like to replace the Harley bearing number 9247 with SKF. Looking for the SKF replacement number.
