Online: beaglebasher, John.R, Hilly
exhaust question
  • berms
    berms
    Anyone know if stock header pipes off a 2009 RK will fit on the 2010 model?   I'm looking into getting some US header pipes without the cats and exhaust valve....
    Thanks.
  • aussiesport
    aussiesport
    hey berms i think they the same bud ..they only changed a few things but the frame itself is same so it should be same exhuast !! scotty would know mate ?
  • berms
    berms
    Thanks mate, just checking to be sure...... headers without the cats and exhaust valve would be nice      I have read that they flow pretty well and with the crossover might flow better than some of the aftermarket true dualls? Need confirmation on that one though...
  • aussiesport
    aussiesport
    yeah scotty did the usa version collector thing but the cross over pipe is still pretty restrictive :/
  • aussiesport
    aussiesport
    dang i knew scotty would know ;) btw scotty any reasons why they changed the sensors etc ?? and why it dont like changing the pipes ?
  • aussiesport
    aussiesport
    so does that mean they are using a diffrent ecu/ecm jigger as well ?
  • berms
    berms
    I think I will just go with a "quiet" aftermarket 2:1 pipe. I just hate the idea of getting done by the law for being too loud.... It wont be long before there is a law on how many squares of paper you can wipe your asss with.
