07 ring gears
  • BACAMICK
    BACAMICK
    had me bike pulled apart and they found a broken tooth , this is the second one so now its time to get somthink better than the HD one , any 1 got  good ideas on a good one , i would like to get more than 10500 ks outa  it
    BacaMick, i got a s&s clutch for my twin cam they come with EVO ring gear and you have to get the EVO starter gear to match, just turns out to be a different ration but main reason they like the EVO ring gear is it has larger teeth. think Bandit Machine works makes a replacement EVO ratio ring gear. my motor starts the same and i have stock starter motor so don't know why they changed ratio.
    do a search or maybe could use an EVO ring gear just get the matching starter gear
    Bring back the kick start! ( we used to break them too)
    good luck BM
  • BACAMICK
    BACAMICK
    nope now  JIMS not avalible  back it goes as it was , should be ok till i can get 1 sent over , goes on the dyno monday n then ill pick it up , seems like weeks since ive seen it
