Online: beaglebasher, DIVOT
fuel light staying on.
  • oz12hungenighty
    oz12hungenighty
     got an issue with my fuel light staying on? anyone know wat this is all about and how to rectify??
    oz12
  • costum666
    costum666
    yeh oz12 I had this issue sent it back "UNDER WARRENTY" had faulty sender unit, cheers666
  • oz12hungenighty
    oz12hungenighty
    thanks 666, ill have a winge to the stealer about it..
  • jim76
    jim76
    i had the same on my 07. took it back under warranty n was told float had a pin hole in it. they fixed it havent had any worries with it since
  • oz12hungenighty
    oz12hungenighty
    thanks jim,
    i turned ignition to accessories tonight and the fuel light didnt beam... so maybe its gone for now.. but if it pops back up ill getr it seen too
  • MapleLeafs
    MapleLeafs
    Haha, so I was thinking someone would have to say something like:
    To fix this problem,
    - Ride the bike to gas station
    - Open fuel cap, and stick gas pump nozzle in
    - Pull lever and fill tank
    - Ride off...
    A strange problem though - one you don't want to be having at all - and glad they rectify it quickly and painlessly.
  • Raymond_one
    Raymond_one
    Same thing on my 2010 Sportster Custom.   Some times  it comes on minutes after filling up others up to 1/2 hour.  Going back for fix next Thursday.  Am thinking of getting the Fuel Gauge that fits as a replacement cap for the front brake master cylinder anyway but will see what happens.
  • Raymond_one
    Raymond_one
  • crackers
    crackers
    What's a fuel light?
    Tis when you open the tank and look how much fuel is in there using your lighter to illuminate the darkness....
    (note: if anyone is stupid enough to try this please set up streaming video first)
  • Raymond_one
    Raymond_one
    About 25 years ago I actually saw one particular moron use his lighter to check the fuel level on a 10KVA generator.  There are some real idiots out there.  His jaw was sore for weeks afterwards.  Not by my hand though.
  • majorboot
    majorboot
    cant say as I have had this problem...cos i don't have a fuel gauge.
    BUT..I do have a tool bag full of frangers.
