horrible noise
  • squid1
    squid1
    my 2007 softail starts first time good but when it gets hot  and i start it again it makes a horrible noise sounds like it does not engage properly to the starter motor the battery is a bit over 2 years old  thanks
  • billie
    billie
    mate I will keep a watch on this my mates soft tail dose the same is sounds like the starter drive and ring gear are clashing badly His is under waranty so I cant pullit apart to have a look
  • toxic
    toxic
    squid spoke to me about this, if your bike has any of the symptoms, get it looked at ASAP,,,,,,,,,,, it's not a good outcome if ya do nothin .........
  • Peter
    Peter
    You haven't given much of a description of the sound that your bike is making or for how long it has done it but, this is some info from another forum - Hey dudes! That "cracking" sound you are hearing is normal. Ya, I know that is what the dealers all tell you when you call something to their attention and they don't know what it is. I have a new 2009 and it does it too. It is a little bit more pronounced when the bike is hot and restarted, but they all do it, really. My buddy rides a 2008 with low mileage on it and it does it too. I have purposely hung around large congregations of bikes when they start up to leave and it is very, very, common. I have always figured it was selenoid popping into gear, but don't know for sure. I will admit, it is a little disarming when you first hear it. My first time I thought it was a rocker arm which had broken loose.     What these guys are talking about is normal with the starter but I'm not sure if this is your problem ??
  • toxic
    toxic
    he has it in the shop now getting fixed, will post the outcome when he lets me know ....
