Online: John.R
FLSTSC Swingarm
  • 8ttimo
    8ttimo
    Hi Guys
    I would like to swing a 250mm rear tyre on my '07 FLSTSC Springer.       Everybodys 1st comment is  " whats the prob - just fit a wider tyre ? "
     Ha -  I wish !!
    Unlike 99% of the '07 range that come with a 240mm rear STD,  The Springer has a 120mm rear.  Genuine parts are too expensive + Harley dealerships are reluctant to try suggest or supply parts to do this,  Zodiac cant tell me if a '07 Softail swing arm will fit   &  their primary offset for softails is 25mm ?
    Looking at bike    i think 25mm is too much,  It seems the primary is already offset 12mm more than my older 2000 FLST ?
    So my Question -  What is correct & who makes the parts to WIDE ASS my Springer ???
    Any suggestions or part #s would save me a headache
    THANX
