BAR WIRING
  • Sparra
    Sparra
    Just wondering how you fella's go about running your wiring down through you bars...Do you dismantle the switch blocks,run the wires and then reconnect the switch blocks...Just cut the wires down by the tank ,run them through the bars and then just re-join them or do you chase them down through the harness until you find where they are joined,do the job through the bars and then join them back into there original position...
    Cheers...Sparra
  • Ozbiker69
    Ozbiker69
    yep all off the above work well for me here
  • aussiesport
    aussiesport
    dont run ya wires thru taller z bars ??!! doh! but yeah all of the above try and keep some sort of sheathing on them ..
  • BACAMICK
    BACAMICK
    i put a peice of string down then suck it through with a vacuum , works a charm  and cost $0  then ya conect a wire to string then the loom to the wire
  • redmick
    redmick
    Or push a draw wire down the bars connect the others to it and pull them back up.When i changed the bars on my 2001 nighttrain i ran new wires back to the plugs the only thing you have to get hold of is the correct crimpers and pin connectors to do the job properly, saves joints which if not done properly might give trouble later
  • black29d
    black29d
    There is a thread on this forum with instructions, I have to find it
    I used the string with a small nut on the end to thread through my bars
    Remove the plug from the plug end, they are designed to be dismatled, write down the wrining colours to pin location, before you start
    also be cearful of the wires that a simular in colour.
    it might pay to enlarge to holes that the wires come out of to allow the heat shrink to come through and make sure that there is no sharp edges
