Bigger headlight
  • Yudster
    Yudster
    I have a 2003 model Sportster, keen to change to bigger headlight.
    I am sure some of you have done it before, what kind of headlight suits the sporty and where do it get it from.
    I called HD, they said nothing suitable for 2003 model, and the custom headlight would be too complicated to install, to the extand it's not worth it.
    Please advise, thank you.
    The Stock Light is 5-3/4. I sell a High Quailty Billet 7" ADR Aproved Headlight , there not cheep or Plasitc $495.00
    This thing will light up a Football Ground
  • Rooster
    Rooster
    I really like that look Walker. And $495 is pretty good, I have seen $700 for the same sort of thing.
    hi, do you need more light or just don't like the looks , if you need brighter light  you can just change the quatz globe to a more powerfull one e.g. 80/100 watt or bigger you need to install a relay an a H-Duty 3pin plug on the connector for the back of the globe as it can get pretty hot  a little air vent could help also  i have seen 80/130 watt fitted in stock h/light ,  D.I.Y. for under $100,
     i can see for miles & miles  as the song said , cheers
  • Sprocket
    Sprocket
    Hey Walka,
    That looks like just what I need.  Most of the roads I travel on the way to work are unlit country roads with limited sight distance with heaps of roos (read: didnt quite miss roadkill left on road at sharp bend by cager) or highways.
    Would that bolt straight onto an 08 1200C?
    Sprocket
    No problem
  • Sprocket
    Sprocket
    Walka,
       At Chrismas, I am going to ride to Perth and back. I was wondering if I was to ride to Melbourne one Saturday lunchtime in around two or three weeks time if there would be any chance you could fit it whilst I was there? If it is possible, I would arrange a firmer time with you closer to the day.
        ...You can never have enough light. Only last Friday at 5.30am a motorcyclist in Canberra died after hitting a dead roo on the the Barton Highway.
    Even more reason for me to upgrade the lights with the dark mornings.
    Sprocket
    I dont fit Parts at work, but I can get Joe Pega from Pega's Custom Cycles to fit it for you . He is just around the corner from our Shop
