Online: B0nes
alarm
  • BACAMICK
    BACAMICK
    guys i need to turn my alarm of so i can drop my bike of at the dealers and levea it to get some work done on it , i wana be able to bring my keys home so it cant be started , work im getting done dont require bike going
  • BACAMICK
    BACAMICK
    cheers mate will try that
  • BACAMICK
    BACAMICK
    cant get that to work , any other ideas ?
    thanks guys
    Mick... you got alzheimers.... www.hdforums.com.au/Default.aspx your same question back in April last year and you said copied and printed
    16 Apr 2008 8:31 PM Quote Reply Alert
    thanks guys ,but these are both 2007s , no button to push , prefere not to pull the fuse as its got a T/MAX
    gota take me f250 full and the bikes on the back , missus in the car and removal truck behind  shit i hate moving , havent moved 4 probly 10yrs
    Thoughts determine what you want...... Action determines what you get !!!!
    MagillaUser is Offline
    Forum Legend
    Forum Legend
    Top End. NT
    16 Apr 2008 9:04 PM Quote Reply Alert
    FOB in hand
    Switch ignition to ignition
    Off/run switch to OFF (on handlebar)
    Switch ignition to Acc
    Hold both indicator switches (should flash once)
    Ignition to off
    Flashes 3 times - done
    Re-arm: Ignition to ignition
    Off/run switch to run
    Write it down, do it a couple of times, then do it again the next day. You'll remember then (only if the drugs weren't to strong when you were a kid)
    2008 FLSTF Fatboy
    105th Anniversary #812/4000
    BACAMICKUser is Online
    Motor Head
    Motor Head
    WEST WIMMERA VIC
    16 Apr 2008 9:13 PM Quote Reply Alert
    thanks mate thats wat i was after
    copyed and printed  as i wont have the net for a few weeks  how the hell ill survive i dont no , might need  to go back to the drugs
    [script removed]
  • BACAMICK
    BACAMICK
    uncle ,Mick... you got alzheimers,,
    na just not vert smart , but i can lift heavy things
    i lookt every where 4 that post in general , never lookt in how to , the printed  peice is long lost ,
    scotty there only swapping front drive pullys so travel mode should do the trick yer ?
     ive got a thing about  ppl starting my bike and not using  the comp releases or as the last adel mec said i didnt see the realises   started gears are $$ when i should not need new ones , this is my madness behind it
  • twincam88b
    twincam88b
    I have a question about this as well. When I go to Tassie on the Spirit of Tasmania, will I have a problem with the alarms going off?
