Online: wildchild, Hilly
? Relocating front indicators on 04 FXDL
  • Ozbernie
    Ozbernie
    Just bought myself a nice low klm 04 FXDL. Rides a fair bit smoother and goes harder than my 2 old shovelheads did
    Wondering if there is a kit available to relocate the front indicators to the lower triple clamp on a 04 FXDL that is closer fitting than the HD item?
  • Kiwibouncer
    Kiwibouncer
    No you would not have to buy the HD ones first but it would require you to rewire them if they are being moved from the handle bars. Check this post to see what they would look like. There is also some other options there as well. I brought and fitted the HD ones but didn't realise how far they would stick out. These are a cheap way to move them closer.
    http://www.hdforums.com.au/Default.aspx?tabid=71&forumid=24&postid=150122&view=topic
  • Ozbernie
    Ozbernie
    Would these be any good?
    http://cgi.ebay.com/ebaymotors/39-MM-TURN-SIGNAL-CLAMPS-4-HARLEY-DAVIDSON-SPORTSTER_W0QQcmdZViewItemQQ_trksidZp3911Q2ec0Q2em14QQhashZitem518a1a7eafQQitemZ350209343151QQptZMotorcyclesQ5fPartsQ5fAccessories
