Online: Stuart
Need to know Odyssey Battery for 88 Softail
  • nitrohd1
    nitrohd1
    Hi Guys,
    I need to know which Odyssey battery I need for an '88 FXST Softail.
    Is it PC535 or PC545???
    Dimension of PC535 are:
    Length 170mm x Width 99mm x Height 157mm
    Dimensions of PC545 are:
    Length 178mm x Width 86mm x Height 131mm
    Anyone know or can check their battery - its urgent!
    Ben
  • nitrohd1
    nitrohd1
    I needed the advice urgently that night, just hoping that someone with a softail was reading.
    I bought 1 of each in the end from TNR batteries in Santa Ana, california for less than 1 battery here.
    They're going in the container along with the new bike!!
    Looks like both batteries will fit so will just pick one when they get here!
    Which ever one I dont use goes in the dragbike which need a new ignition battery anyways!
