Online: John.R
EFI + Filter advice
  • DNO
    DNO
    The K&N is also a good option, my pick however is the Zipper Maxiflow. I 2 have had the Big sucker backing plate crack. As for a SERT, well it would be OK if you could tune it without limitations, go a TTS or PC5.
