Online: B0nes
rear brake lever on fatbob.....
  • toxic
    toxic
    had a scary moment on the way home from work 2day, was riding next to a guy who was about 1 bike length in front of me when a dickhead starts to turn in front of the both of us, his BMW 12200 GS veered right into my path, I went for both brakes but missed the fucking rear lever, the fronts did their job but I scared the shit outta me,
    What I'd like to know has this happened to others, has anyone looked into fitting a different lever or something that would make the rear brake lever longer ???????
  • pisspour
    pisspour
    had thought of modifying brake
    but am investigating a different air cleaner hopefully to keep my leg/foot in a bit tighter to the bike
    thankfully no close calls where i've needed to find brake in a hurry
  • 1elcys
    1elcys
    Know what ya mean Tox the brake pedal is tiny.
    You can get a kuryaykn cover for it and you can get a cheap chinese knock off cover that works ok too it makes the pedal face wider and longer.
    Heres some links
    http://www.kuryakyn.com/index.cfm/go/Home.ProductDetail/catID/10/scID/91/IMID/617
    http://www.realhog.com/detail.cfm?model_ID=0&Category_ID=6&manufacturer_ID=16&product_ID=8633
    http://www.realhog.com/list.cfm?model_ID=0&category_ID=58&sblid=Brake_Pedals__Shifters__Covers
  • TC
    TC
    Shit toxic not good.Keep us informed on what you end up with would be keen to know.
  • toxic
    toxic
    I made some calls & after filtering the crap, came up with a replacement pedal cover that is slightly larger ( longer by about 10mm ) from the parts guy, it's from the diamond plate range of HD bits, pulled the rubber one off & screwed the replacement on, the slightly wider parts gives me a bit more pedal to get to but only time will tell.
    Got the whole set on special, pegs x 4, brake & shifter as well.
    We tried the larger one off the touring range but it didn't fit or look right, one looked like a push bike pedal, YUK !
    I have a lead that Kuyakin ?? have a pedal that goes over the existing rubber one, but have had no luck tracking down the info.
    Will keep ya posted & put up some pics soon.
  • toxic
    toxic
    well yeah it was a spinchter moment, but my guess is his eyes were wider than mine, I will get some pics up soon......
