Online: John.R
open belt primary
  • kiwi
    kiwi
    Hey guys am interested in a open belt primary for my 07 dyna(2 or 3 inch)just wondering what would best suit the bike and a price for the installation also would it need another map.Thanx guys Kiwi.                s.e.p.s.t, high flow air filter,v/h shortshots,se204 cams.
  • kiwi
    kiwi
    Just wanted it for looks really and the nice whistle sound they give out.
    hi ,  dry open clutch  is very  loud when disengaged,  & can also change the pri drive ratio depends on the brand name used,   be carefull there's  alot of shit out there  primo is a good brand , don't think much of BDL ltd , iv'e seen a few fall apart after a while  ,  also no adjustment on the dyna for the belt tension not like the old SHOVEL  cheers
  • twincam88b
    twincam88b
    Funny enough I was going to ask the question tonight, re:- what are the pro's and con's of open belt primaries. All answered here. Thanks fellas.
  • nitrohd1
    nitrohd1
    I never needed rubber bands in 20 years!
    Gets rid of that useless thing called a compensator sprocket.
    Cleaner - no oil to leak out the primary
    Looks good!
    I ride in the rain, on dirt roads, anywhere really - its all good!
    Can affect gear ratio's - just pay attention and do the maths - its not hard..........
    If I want to tighten up the clutch or adjust the pushrod play its a few minute no brainer!
    Had one on my rigid shovel chop for years, new softail coming has one as well.
    BTW did I mention they look great!
  • monarofan
    monarofan
    i,ve got a 3 inch BDL on my chopper, no problems with it as yet, noisy with the clutch pulled but the sound of it running in gear makes up for that , chewed the backs of a few shoes out but no jeans as yet, you soon learn where your feet go ,
    the only thing is that any open or exposed primary belt setup is illegal,
    but hey, so are a lot of things, fuck the fun police
    I did a bloody lot of miles with a Shovel with a primo belt drive Bandit clutch, kick start only. when i had that you had to make everything yourself. sometimes was a pain in the arse, but if you had it set up right was trouble free.
    but i would not change to open belt drive now the closed in chain is best. but if you must go for it , just i got a few stones between the belt and the pully and thats bad news they wear the pully gears and can push a hole in the belt, also have seen some belts throw off, never happened to me but seen it happen to another guy. they are good kick start only!
