Brake Master Cylinders
  • 2005 FLSTFI
    2005 FLSTFI
    Does anybody know if Harley do a 5/8 port brake master cylinder for the front, if so do you know what the P/N for this
    Since putting 6 pot calipers on the front the brake lever is alot harder to work to pull up compared to stock. I was thinkin maybe a bigger port would fix this issue.
    They do a 11/16 but they are for the tourers which have twin discs on them
  • DynaRider
    DynaRider
    if you are saying that the 9/16 m/cyl is too firm, it will only get firmer with 5/8
    thats why hd went to 9/16, to reduce lever effort (while adding a little travel by default)
