ZOMBIE GRIPS
  • Midnite
    Midnite
    I just installed the kyrakyn zombie grips and they look the part but i noticed 4 mm play from side to side on the throttle grip. I asked around and tried a ISO grip already installed on a softail and it too has that movement. Anyone has a kyrakyn grip on their bike and do you have the movement as well......? has anyone come up with a solution to fix it?
    zombiegrips.jpg picture by midnite9227
  • grafpak
    grafpak
    4mm?.if it don,t fall off dont worry!!!!!!!!!!!!! ps..evil levers!!
    I want the levers - they are free right?
  • grafpak
    grafpak
    jilli try a tool supplies that sells nuts and screws..if not post the otherone to me and i'll get you a couple(in melb)
  • Midnite
    Midnite
    I have gotten used to it now, "If they dont fall off dont worry about it!", going with that theory but i am a perfectionist when it comes to parts fitting exactly those little things get to me the most. but i can help but love the zombie grips and levers, argh the irony...
  • Midnite
    Midnite
    Hi Jilli96, what harley model do you ride and year? there are exactly like except for the ends - no worries about the hijack lol
  • costum666
    costum666
    i had same 3 to 4mm of play & did 10,000ks without falling off its all good bro. Zombie grips are off tap
