Online: Kato
Dot 5 brake fluid
  • Peter
    Peter
    Does anyone know if it is ok to use Dot 5 brake fluid instead of Dot 4 in late model bikes. I understand that it doesn't affect your paintwork if you spill it, the workshop manual says only Dot 4 but a friend is running it in a 95 softy and hasn't had a problem with it. Any thoughts anyone ??
  • Peter
    Peter
    It's ok all,I just did a search and answered my own question. I did that ass about face
  • Magilla
    Magilla
    And the answer is?
    I want to know as my front master cylinder has been leaking at the cap seal and stuffed the paint on the controls
  • blueystar
    blueystar
    good to know just change my brake line was about to put in dot 4 beening a late 90 model i better get some dot 5
    thanks for the info
    bluey
  • snagger
    snagger
    Interesting stuff....my 85 FXR has  changed from one to the other over the years.
    only cause of the paint issue.....things are still okay...hope it stays like that ...
  • Peter
    Peter
    Hi Magilla,I did a google search -dot 5 brake fluid- tells you everything you need to know.
  • blueystar
    blueystar
    dot 5 $17.01 plus gst at frasers got a bottle to day
