whats a good 2 into 1 pipe
  • hellboundpig
    hellboundpig
    whats a good 2 into 1 performance pipe would be nice if it was black ceramic coated my build is 07 softail fxt 103 211 cams screaming eagle heavy breather ported heads 0.30 cometic gaskets .
    cheers HBP
  • aussiesport
    aussiesport
    d and d fat cats or v and h propipe??!!
  • BACAMICK
    BACAMICK
    D&D fatcat NOT the D&D BOARZILLA
  • hellboundpig
    hellboundpig
    Is D&D low cat any good i was looking for a tuned length headers.
  • hellboundpig
    hellboundpig
    FYO do you think the D&D low cat would have close to the same torque cures just like the look of the shorter pipe bro.
  • Mainey88
    Mainey88
    Got the black fat cat on mine and they are a nice system, they fit perfect and I like the flange gasket set up. For the first few rides it does pay to keep the flange bolts tightened up, no leaks no popping or backfiring.........................
  • Tux
    Tux
    I have the black Supertrapp 2 into 1. Only the outside of the muffler and the heat shields are ceramic, the rest is black chrome. I was not happy with the finish and fit. I would have to think carefully before I bought another set.
    Tux
    A few people have posted how long they had to wait for those pipes to be made.
    on there sight in USA they say they are hand made so take time, should e mail the place in QLD see if they have any in stock.
