Online: GGUser744, StephenB
Decel enleanment
  • Fr3d
    Fr3d
    Hi, Just want an idea about DE adjustment.  Do I apply an even increase of the multiplier over the total temperature range or do I just select the say from the 96 degree and up?  Also what sort of increments should I make?
    Thanks
    Fred
  • Fr3d
    Fr3d
    Thanks for the info.
    I am only doing the the DE on a open loop map that I need to run the bike till I sort out the rear sensor. After a bit of trial and error the TW205 map seemed to run the best although a little restricted and decel poping. I basically changed all 14.6 cells to 14. Good canned map that seems to go well with the build. When I have the rear sensor fixed I will be able to do my Vtunes and get the map right.
    But getting back to changes made to DE. Do I apply the say 5% change over the whole range of temperatures or just in the higher operating range?
    Thanks
