Fat Bob mid mount foot controls
  • rockyrob
    rockyrob
    I am finding that on longer rides the standard foward controls are not as comfy as i would have thought and i start looking for more leaverage to take the weight off my back. my thought was to maybe put a set of mid mount pegs on as well just for resting feet on  not moving the brake and gear controls,much the same as highway pegs on a mid mount bike only in reverse. I can see where the mounts go onto the frame, currently two holes with rubber bungs about  50 mm apart, there must be a block or some sort of mount that bolts onto the frame and then accepts the pegs, I cant find any clear pics or a part number for the mount (block) or whatever it is. As the Fatbob only comes with forward controls in Aus i dont expect anyone has had to do the conversion and  has left over mids for sale but i am thinking there must be  a lot in the US that started with mid and changed to forward.
    Sorry for the longwinded explination, but my question is,  Is it called a mid mount mount , can anyone tell me how to find a part number for it. and does anyone know a good swap sell site in the usa i might try first instead of buying new. I thought of making uo my own  but would like to keep matching pegs for a nice look
    Thanks
    Rob
  • rockyrob
    rockyrob
    Thanks for the prompt reply,  if i were looking for them  would that give me the mounting plate/block whatever it is tho. . there must be something that spacers out to clear the exhaust and have the female slot  that the pegs mount into
  • FatRob
    FatRob
     You will find the parts you need on flea-bay,  The foot controls crop up regularly, see this link as an example..
    Item number 350213890660
    http://cgi.ebay.com/ebaymotors/Harley-Davidson-Dyna-FXDB-FXD-DRIVER-CONTROLS_W0QQitemZ350213890660QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item518a5fe264&_trksid=p4506.m20.l1116#ht_5737wt_895
    And you'll need to change the primary outer case too for one that has the hole for the gear lever spindle.  Look at item number 150368831921
    http://cgi.ebay.com/ebaymotors/Harley-Dyna-Softail-outer-primary-STREET-BOB-FAT-BOB_W0QQitemZ150368831921QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item2302ae49b1&_trksid=p3911.c0.m14#ht_500wt_1025
    Good luck - I'll be interested to see how you go as I intend to do exactly the same someday - soon, I hope!
    FR
  • rockyrob
    rockyrob
    I dont intend to move the gear or brake controls so i think i am just after the mounts for  the pegs, once i fit them ,  i will match with the current HD chrome and rubber ones i have fitted on the forward controls
  • rockyrob
    rockyrob
    Just had a look at that link to ebay,  it is the black mounts that i am chasing,  the other controls are not necessary for my situation.  IT may be easier cheaper to buy new mounts. Thanks for the pic  it makes it easy to see and expalin what i want now
  • FatRob
    FatRob
    Sort of reverse highway pegs then - novel idea.
    But you'd just need the footrest mounts and the pegs then.  I'd be willing to bet that there's a few forum members that have taken either a Street Bob or a Dyna Glide to forward controls that have just what you need in their shed.
    FB
  • rockyrob
    rockyrob
    Thats what i reckon , most street bobs would convert to forward, i will check my dealer he may even have them lying around from a bike that was fitted when sold. , I think it will look ok , there are lots of dual peg bikes around. and they would be easy to take off and refit for long trips etc,
  • rockyrob
    rockyrob
    Thanks to Fatrob  i can show you guys what i am after,maybe you have  taken them off your late model streetbob  dyna
    All i am chasing is the black mounts  I do not need the levers at all .If anyone has they dont need/want and are happy to seel them please give me a call
  • rockyrob
    rockyrob
    Thanks Rodder i will check that out, Do you want to sell the mounts AKA  if so PM me and we can sort something out
  • rockyrob
    rockyrob
    That,d be xxuckin right  i come up with the idea  and some prick beats me to it  lol story of my life,
    Rodder  may be right ho looking at the US fatboy pics, theres a definate notch in the heat shield  which can only be for the peg by the looks so it might not be the cheap fix i thought as i still have the standard headers for a while yet
  • TC
    TC
    Hey Rockyrob
    I found my forward controls a little uncomfortable, so have just fitted a reach seat ,now they are just fine.This may not be the answer for you but worth thinking about??
  • DynaRider
    DynaRider
    the footrest support brackets are not that expensive new
    it is not totally uncommon to see the mid mount pegs still fitted with forward controls
    2 of my mates already have that set up
  • rockyrob
    rockyrob
    Thanks guys for the advice ,its not the reach that is the hassle its more the position of my knee resting on the air cleaner and the angle that seems to kill my lower back after a while, Only ever having British bikes or MX before the Fatbob I guess i am used to the upright style of the mids, Suggestions are apprectiated, Have got my stealer looking into his bin for an old set left over off a mount move or will consider new .If anyone has a set i,d be happy to hear from you,  Cheers
  • Bli Bli Bandit
    Bli Bli Bandit
    just hang your feet over the rear pegs when your back gets sore, only need to do it for a short while and then you will be good to go again.
  • rockyrob
    rockyrob
    lateral thinking there Bli, :)  I picked up  a set   the dealer had laying around  so  will see how it goes,
  • FatRob
    FatRob
     Just out of interest, how much did the dealer sting you for the mounts?  Black or chrome?
    FR
  • rockyrob
    rockyrob
    70 bills chrome which was ok  i thought  , they were around 200 for both new in black. fitted yesterday yet to try them,  the heat shield was touching only with the bike running and weight on the peg  so a bit of work on the mount with the angle grinder and its a perfect fit now,  put the original black rubber pegs on  and they  are hardly noticible when folded up,
  • weepete
    weepete
    rockyrob,
    let us know how the mid mounts work as Im in process of acquiring a 2010 Fat Bob and just know that I will need said mod.
    as I like long rides and am an old fellow who needs to be comfortable but dont fancy a goldwing.
    Currently Vstar 1100
    As soon as shipment arives Black Denim Fat Bob
  • rockyrob
    rockyrob
    they work great  ,  only need to put the fett down for a while and its all good again,  or  if you want to get twisty in the corners it gives a whole new feel   i will take a couple of pics and put them up ,
    RH peg  hits exhaust, (original tommy gun) when engine moves  but that is easily fixed with a quivk grind to the underside of the peg
  • rockyrob
    rockyrob
    Couple of pics  of the pegs
