Online: perthhog, Muzza Wa
Opinions on this build
  • 2005 FLSTFI
    2005 FLSTFI
    G'day Guys
    Just thought I'd run this build past the experienced engine builders.
    Out'in the SE 211 replacing with Andrews 37G, S & S Gear drives, SE Flat tops, 95 Big bore with a TTS Tuner looking after it.
    With this should I use a 0.30 HG or will this have to much Comp. or just use the stock HG
