Online: beaglebasher, John.R
my sporty build stg 11
  • grafpak
    grafpak
    hi all ,this is my 2007 883 sporty just finished some work this winter...
    -1200 barrels&screaming eagle 1200 heads
    -freedom detonator pipes&s/e heavy breather
    -pc 111 & custom dyno tune
    -burliegh 10" bars+mirrors grips&pegs
    -mustang solo seat &licks solo saddle bag
    -11" dyna progressive shocks&side mount plate& mini blinkers
    -2" tank lift ,wire tuck& coil relocation&4.75" ext fwds
    all custom work and engine ass by me!!
    the last photo shows the black derby cover the earlier photo's show it in primer...cheers..dc
  • kingchops
    kingchops
    Grafpak,
    Bike looks awsome, I like what you've done with the rear fender. I bet it goes great too with the engine work. Nice job.
    P.S - I changed your pics so they show in the post, much easier to see.
    Cheers,
    KC
    I was thinking a bobtail type fender would finish it off perfectly (and a black bag) but everyone has different tastes :)
  • brucecul
    brucecul
    i like the placing of the coil. get much out of the 1200 kit ?
  • Rooster
    Rooster
    Hey dc,
    The build looks really good, I like all you have done to it.
    Some questions:
    You must be a tall bloke, does the mustang seat sit you further from the standard front peg position or closer to it?
    Where did you get the mustang from and how much? Did you get an 12.5" or 14" wide seat?
    I was looking at getting 3" forward control extensions for myself (I'm 6'2), where did you get yours from? I see you went with 4.75".
    Well done with the conversion.
    Thats not bad
  • grafpak
    grafpak
    hi rooster, i got the seat off this forum its the smaller 12.5",but i was about to buy one from mustang direct or wisconsin harley davidson.and i don't think it moved me much at all but is much more comfy on longer rides and stops me sliding back on quick take offs . it does raise you a little over the custom hd seat...the fwds on mine are
    2" dog leg pegs from zodiac + 2.75" ext mounts by me and both rods ext to match and i added adjusters to the rods so i can adjust up or down for the pedals(makes it much easier changing gears!)
    cheers walka..
  • jim76
    jim76
    Very nice. where did u get the bag from? i have been thinking of getting a bag like that for my bike but in black. n if u dont mind a price as well thanks
  • grafpak
    grafpak
    jim76 ,bags from licks cycles in us about $350-370 aus..
  • sportytrace
    sportytrace
    Hey... It's looking good... the tank lift really flows well with your mustang seat, especially through to the fender; nice lines :) I think the mustangs often look like the sit a little too high, but yours looks right at home with the changes you've made.
  • Sprocket
    Sprocket
    Grafpak,
      Great looking bike! Top work!
    I am keen to know do the licks bag mounting straps rub any of the paint off the bike frame or swing arm?
    Can you add any photos that show how the bag attaches to the bike?
    Sprocket
  • grafpak
    grafpak
    thanks sportytrace ,i agree i didn't want the mustang but its so comfy!!!
    hi sprocket, tha bag does rub slightly on the battery cover i just put some stick on velcro on the bottom of the battery cover(probably should have stuck it to the back of the bag!)and all seems good now..
  • haynes-davidson
    haynes-davidson
    awesome and more awesome.
    not over done.  just right . simple looking and yet powerful.
    classy.
    congrats bro.
    cheers - Haynzy
  • grafpak
    grafpak
    cheers rodders ,yes i'll keep the sporty for good now maybe a 88 cube conversion in a couple of years and i might get a dyna for a travelling bike? keep the sporty for hooning around town!!
    cheers haynzy.............
  • costum666
    costum666
    bro, bike looks wicked. I printed some pics to show the big boys what u can do with sporters
    cheers666
     hi,  have you ever been out in the rain with no front mudguard  with an open face helmet & no shades ?  lol ,   cheers   i like all bikes but iam a sporty nut
  • grafpak
    grafpak
    cheers costum666, dr56 yes in heavy rain it kicks up a bit of water!!
  • Taffymarsden
    Taffymarsden
     Great bike! Can you get away with that side-mounted number plate in Victoria? No hope in NSW.
  • oz12hungenighty
    oz12hungenighty
    nice work graf, looks great!
    did you powder coat the primary cover or just spray painted??
  • grafpak
    grafpak
    cheers , primary cover painted in high temp paint same as engine barrels...mates have side mount plates and no probs..
