Broken headlight
  • TC
    TC
    Broke the headlight again on the fat bob, the first time I suspect a rock hit it.I was Quoted about $400 so being a tight ass i had a glass cut at the local windscreen joint and then put some stick on film over both lenzes.Now it has cracked again suspect another stone.So Im thinking of going to a single headlight Anyone have any knowledge of the wiring loom fitment do most harley headlights have the same wiring plugs at the headlights?
    Thanks Tony
  • snaggs
    snaggs
    cant help as far as wiring go , but most headlights are the same dia as cars as i know due to stone damage.And most auto parts stores will have the same thing but between 30 to 80 dollars approx.Another thing i did was buy some invisable headlight  cover material which comes in a pack of 2 and i got from supercheap. cheers snaggs.
  • PigironBob
    PigironBob
    I have a Fatbob headlight here if you want it, cost ya $50 plus $20 postage.
    Then I suggest you get some headlight covers from www.amhp.com.au/  Dyna Fat Bob FXDF 08-  $64.00AU
    Bob
  • TC
    TC
    Thanks Bob I will send a PM
  • TC
    TC
    Thanks shaggs
    I have the clear headlight protectors but they did not help in this case i will buy the light from pigiron bob and have another go at the standard light
    Thanks again Tony
