Online: B0nes, Hilly
Changing Clutch Cable
    Hi all, this might sound like a stupid question but here goes anyway.
    I have to put a new clutch cable on my bike a 2001 Dyna Superglide and I
    want to know if you have to drain the trans fluid first or can you just take the
    side clutch off without draining the oil.
    thanks in advance.
    Brett.
  • BACAMICK
    BACAMICK
    on the side stand ull loss little
    PS: dont tighten up that cable into the housing where the oil is to much or it WILL CRACK
    dont bend that cir clip , be carfull and watch out for the ball bearings, do it looking down on it, IE rag on floor /missus holding onto the housing while u do  it
    Thanks Bacamick I will give it a go tomorrow.
